behengold
Oct 24, 2015Explorer
Flo jet macerater pump won't fit sewer line output
I assumed sewer lines were universal.I tried to use my flo jet on my new used class A and it won't fit.The new output fitting is approximately4.5". The flow jet is around 3.75". Tried to buy a new fitting at Walmart.That doesn't fit either. Are there adapters? I was thinking maybe buying a hose extension to see if that would work. The previous owner added a 3d valve and section of pipe in case one of the original grey or black valves failed. Wonder if he changed the original diameter.
