garymunson's avatar
garymunson
Foggy double-pane windows
Has anyone had luck disassembling and cleaning the interior surfaces of double pane windows and re-assembling them? My 2004 Fleetwood Flair's driver and passenger side glass (fixed panes) have fogged up inside. Seems like it should be possible...
  • Mountain Air 05 was a great help to me when I needed to remove my front side widows because of fogging. What he said is true, he has the answers. I used a vibrating multi tool to separate the 2 panes of glass, as it was much easer and faster the using a kraft knife, or putty knife.
  • I removed all 8 of mine a few years back and took them apart, cleaned and applied new spacer and sealant and install back in with breaking a pane. The first two is the learning curve and after that you can easy do one/two a day depending on how many are doing it. Cost was less than $200 for all 8. Pm me if you need info.
  • Has anyone removed a window from a 2004 vintage Fleetwood product? Looking at it, I'm assuming if I remove all the interior trim ring screws, it will come off and the main window assembly can be 'un-stuck' from it's sealer and removed to the outside of the RV. Once it is out, is the insulated glass panel just held in the frame by it's rubber perimeter seal?
