Mikeborny's avatar
Mikeborny
Freightliner light control panel
Has anyone had an issue with their light control panel on the dash acting up? This is where your warning lights are. After about two hours driving my ABS light goes on, then check transmission then check engine. All the guages will go to zero. If I pull over and shut down they all clear and back to normal. Freightliner had me disconnected batteries and see if that reset things. Next day same thing happened about 2 plus hours i to drive.
I have a 2014 berkshire 390bh.
  • Yep same problem 2014 Thor Palazzo. If what you were asked to do doesn't work they will need to replace it. Mine was replaced. I had the exact same symptoms.
