okiejoe wrote:
Well after some good suggestions I went out and removed some panels inside and definitely noted that there was one air duct hose that had a tight “S” curve in it then connected to an air duct in the floor that ran over to the other side to heat hallway and bathroom so I cut a little over 2 feet out and reconnected the duct and WALA problem solved. Thanks so much for all the input. It looks like there was just to much of a curve in the Duck work, it was crammed under the kitchen cabinet & sink. Apparently the restrictions were causing excessive heat to build up and the the limit switch would shut it down.
Thanks again
Wow … thanks for the follow-through on letting us know what the fix was!
We love our RV to be warm so we're sensitive to furnace problems, and we had an expensive-to-fix one recently. What we had was a leaking kitchen faucet over the years slowly permitting water drip down onto the furnace's control board and then eventually shorting out the board. We thought that the faucet's small leak was only onto the kitchen counter's surface and I let it go because the faucet was difficult to get at from underneath.
Thanks to your post above, I'll also check some of the bends in our furnace's duct tubes that run in behind the counter and under the bed area.
