pnichols wrote:
Discussions like the above really are scarry!! It's not "when" ... but "where" the fuel pump goes out that's my concern. What if it gives up way out someplace in a boondocking spot?
I'd pay extra for a special dual fuel pump setup in which two fuel pumps were running in parallel at all times, with a warning light when either one of them failed. Since the chances of both failing at the same time are vanishingly small/near zero, two pumps in parallel would stop any concerns of ever being stranded for that reason. Fuel pump failure is one of the few things that can stop you dead in your tracks and that can't be fixed on the road by the owner or ERS. There's no "limping home" with a failed fuel pump. (Although some owners think that they can replace a fuel pump "fairly easily" if there is an access port in the floor of their RV.)
Perhaps Ford motorhome fuel pumps should be replaced before they fail every ??? miles .... the same as certain other super critical Can-Leave-You-Stranded preventative maintenance items?
Op here...that is why I have some odd parts left over. Our Fuel pump (lift pump actually) fell apart in Yuma. Not even boon docking at the time. Dealer 2 weeks behind (snow bird season) so we went to another shop. We got totally ripped off by mechanic that talked a good story in the beginning but never followed through. We're not going threw that again. Coming back home started leaking around Sacramento area, we did made it home to Seattle, yes with diapers and baling wire wrapped around fuel leak at sump. I now have an back up pump that I can make it to a repair shop of my choice. Just un-bolt (external) failed pump and screw in back up (carter pump) and switch around elec wires, re-prime fuel line and good to go.
Trying to set a similar set up for a gasser, so like you say not stuck. Just flip of toggle switch or what ever so you're not stuck somewhere.
I think the first generation of Humvees had a set up that had to 2 pumps. If one failed other pump kicked in. I'm going to have to do some more work on something that might work.
If I ever do drop gas tank, I'm for sure going to install a bulk head fitting and plug it off for future use, if at all possible.
