โAug-29-2017 07:17 AM
โSep-03-2017 05:00 PM
tropical36 wrote:
No way we'd trade it for a newer entry level coach, at the same worth, that's for sure.
โSep-03-2017 08:12 AM
Colo Native wrote:
I am looking to go back to a MH, I want spend $70K -100K. It appears I could get a 3-4 old gas or a 8-10 year DP. I like the idea of a DP but wonder if the life is used up on a 10 year old DP and I how much $$ to update on one. I have had a gas before and I know they are slow and noisy in the Rockies. Any thoughts.
โSep-03-2017 05:12 AM
โSep-02-2017 11:18 PM
โAug-31-2017 08:17 AM
โAug-31-2017 07:47 AM
โAug-30-2017 08:34 PM
โAug-30-2017 07:16 PM
Bruce Brown wrote:I would lean towards a DP if I wanted 40 ft MH but in the shorter sizes they are hard to find. Saw a nice winabago 32t with a 350 HP engine but it had no pass thru storage. The CC allures and Intrigues are nice but they are hard to find. I don't want to start a torque vs HP debate but from a pure performance stand point I don't think a MH that weighs 30,000 lbs with 300 HP will out perform a 15,000 lb MH that has 362 HP. The gas engine may sound like it is going to come apart at 4500 RPMs and the diesal is just chugging along at 1400 RPMs but that is all in the design. The increased torque may be better from a stand still but if each approaches a hill at 40 mpg I think the one with the highest HP/ WT ratio will be at the top sooner.Gjac wrote:
One thing to keep in mind is a short gas MH with 362 HP and weights 16,000 lbs will have a higher HP/wt ratio than a 300 or 340 HP DP that is closer to 30,000 lbs. Gas MH's have the same engine whether it is 28 ft or 38 ft. DP's HP go up as the length and weight go up.
True, with possibly one *.
In the diesel world torque is the better number to look at. There is a big difference between a Cummins ISB rated at 300HP/600# torque and a Cummins ISC rated at 300HP/950 # torque. HP sells stuff, torque is what gets the work done.
Seeing as the new Ford V10 is rated at 320HP/460# torque and the lowest rated ISB today has 660# torque, it's something that needs to be considered.
With that said, I'd still lean towards a diesel, there are just too many other benefits other than the engine.
โAug-30-2017 10:29 AM
โAug-30-2017 08:30 AM
Colo Native wrote:One thing to keep in mind is a short gas MH with 362 HP and weights 16,000 lbs will have a higher HP/wt ratio than a 300 or 340 HP DP that is closer to 30,000 lbs. Gas MH's have the same engine whether it is 28 ft or 38 ft. DP's HP go up as the length and weight go up.Busskipper wrote:Colo Native wrote:
Only you will Know the right unit for You - Floor plan and Level of Fit and finish will likely be the deciding factors.
IMHO, the older diesel will give you more of what you are looking for.
Comfort - Ride - Build level - just a better House.
Just a guess but I think you have a strong lean for the Diesel.
Have you narrowed down the list to a Manufacturer, or two? Think that will help.
In all honesty the size limit you have will tend to be very limited in the used market, and as you know there are just so many more 40' Coaches.
So, if I were you, figure out the Type - Diesel or Gas - ID your level of Finish (Not just on the surface) - Narrow down to couple of Manufacturers - Search till you drop.
Then run the heck out of it, see the rest of the Country,
Now ----- what will be the Toad?????????????? Be sure the selected Coach can pull it where you will travel.
A 400HP non DEF should be possible, and would be my preference
Keep us all in the Loop as this will be FUN to watch as it evolves.
Best of Luck,
ps. as I've read many or your posts over the last few years - you have a strong knowledge of your needs and what will work - my story is I had a gas unit that just could not handle Colorado so I had a Diesel Build - we selected a Hydro Hot because we use it in the winter - This is a BIG DEAL - so just keep that in mind - Insulation is also Critical if you use it in the Fall/Spring/Winter.
Colorado is hard on gassers going up the hills at 35MPH and 4500rpm slow and noisy Been there done that but then again I don't know if a 300-340 HP dp is much better
โAug-30-2017 07:23 AM
Best of Luck,
โAug-30-2017 07:01 AM
โAug-30-2017 05:03 AM
โAug-30-2017 03:38 AM
