Goldencrazy's avatar
Goldencrazy
generator with mind of its own
Anyone had a problem with a generator that for no reason decides to try to start. The motorhome is gas and is pugged into 50 amp. The transfer switch is automatic meaning there is no need to plug the coach into the generator to have power. It does not mean automatic that the generator starts when shore power is lost. For no apparent reason the generator decides to turnover and if it was primed would start if the owner did not get to the stop button first. Any thoughts?
  • Doesn't the generator react to low battery voltage, regardless of whether you have shore power or not? Maybe your battery charger is not charging sufficiently or maybe the generator is coming on to charge your chassis battery which is not charged by most inverter/chargers.
  • Alittle update to this post, originally submitted by Goldencrazy.
    I'm the one that had the problem, Michbill. Goldencrazy was next to me at the campground and beat me to the post.
    I took the cover off the switch on the generator, and it fell apart in my hands. I replaced this switch. The generator would not start, and the carb had to be "rebuilt." It now seems to be working correctly.
    It appears that the problem with the generator having a mind of its own and trying to start by self was because of the defective switch on the generator. Thanks for the posts.
    Bill
  • If you do not have auto start, or remote start, I would just limit the scope to the problem to the remote (hard wired)start switch, and the connections at the generator. If you think it is moisture related, pack all connectors with dielectric grease, and plug them back in. Coat any exposed connectors in the generator with the same grease, or something designed expressly for that purpose. Using silicone to coat the connectors is just asking for trouble, with the wiring.
  • I had a customer have a home standby unit do this. Very erratic at first and finally started and continued to run. The HOA switch was the culprit. Larry
  • I don't know which generator you have, but the Onan Quiet Diesels are known to have this problem if moisture gets into the plug for the control wiring harness which is outside the generator enclosure towards the right side of the vehicle.
  • Goldencrazy wrote:
    Only one person who ever had this problem? Is that a tribute to the quality of the switch or did I post on a quiet day?
    It sounds as tho this has never come up. This will require you to pay particular attention to the symptoms, meaning what's going on at the time the genny comes on. It very well could be a switch(s) with them having bad contacts. It could be the transfer switch, if you have one. This WILL be detective work on your part. I would start to eliminate as much as possible, the weather - wet contacts/moisture. But the switch would be the cheapest one. Can you eliminate the transfer switch - if you have one. Just break things down into blocks and start eliminate any piece associated with the genny.
    Hope this helps!
    -paul
  • Only one person who ever had this problem? Is that a tribute to the quality of the switch or did I post on a quiet day?
  • Community Alumni's avatar
    Community Alumni
    My Onan 5500 did started by itself twice after flipping on the battery cut- off back on. It turned out to be a faulty toggle start switch on the generator itself (the switch on the genny, not the dash one).
