Mar-05-2014 05:33 PM
Mar-19-2014 02:12 PM
Mar-18-2014 02:26 PM
DUNEBUGGYDOUG wrote:CLICK HERE to see the Ford document to outfitters like motor home manufactures on the proper method in changing the wheelbase. There are a number of matters to consider such as brake & fuel lines, wire harnesses, parking brake cable, drive shaft, and welding procedures, materials etc.
Ok fellas, I was not aware that the MH manufacturers streched the wheelbase.I thought they only added. behind the rear axle so I guess the old adage of learning something new every day still stands true to form .The official wheelbase listed for 1998 E-450 is 158"and 176 "while for an E-350 it is 138", 158" and 176" .Thanks J-D and the rest of you
Mar-18-2014 12:24 PM
Mar-17-2014 09:13 PM
Mar-17-2014 07:13 PM
Mar-17-2014 04:55 PM
Mar-14-2014 10:00 AM
ron.dittmer wrote:
... and I've heard a loss of 1 mpg because of the rear axle ratio. But I find it hard to believe it takes a 10% hit in fuel economy.
Mar-14-2014 09:22 AM
pnichols wrote:So it finally happened, Koni offering FSD shocks for the E350/E450. I can't wait to hear from people who get them on their class-C.
Just as KONI promised, here is their E350/E450 solution to at least a portion of the harsh Class C ride coming from the rear suspension ... at least for my case of a small Class C that under-loads and under-works it's E450 chassis:
http://www.koni-na.com/uploads/KONI_E350450_Cons_PR.PDF
P.S. "Under-loading" and "under-working" the chassis under your Class C is a good thing if the harsher ride in the rear can either be tolerated or otherwise addressesd. Some of the benefits are A) larger brakes for more safety and longer periods between replacement brake pads, B) better transmission cooling for climbing long grades in warm weather, and C) thicker frame steel for less stress induced deformation of the RV's flooring and super-structure.
Mar-13-2014 07:58 PM
Mar-13-2014 06:08 PM
ron.dittmer wrote:
There is a draw-back to excessive CCC margin. The ride will be exceptionally harsh. Considering it's a house with contents, less harsh is better. There is a delicate balance between quality of ride and excess CCC with no real formula to follow.
Mar-12-2014 05:32 AM
Mar-11-2014 08:55 PM
Mar-11-2014 05:02 PM
Mar-11-2014 09:30 AM
