heat shield
jtessnm
Newmar Mountainaire 8.3 Cummins Intermittent Electrical problems, Engine would stall, Voltage would fluctuate. Found that the exhaust manifold heat shield bracket broke allowing the heat shield to fall on to the starter solenoid causing an intermittent short
Do not confuse me with facts, my mind is made up.
There is a difference between stupidity and ignorance: ignorance can be cured.
2 REPLIES 2
jtessnm
I removed the shield bracket, welded it and added reinforcement gussets. The original design was poor as all the stress flex was on a narrow strap.
sjholt
Good find.
Did you repair it?
Skip
1996 32' Monaco Windsor DP
Cummins 5.9L 230+ HP
5 Airbags in front- 4 in back
