S1njin wrote:
Are you talking about the front or rear sway bar J-D?
From the front manual - Remove the factory front sway bar keeping the original bolts and nuts to be reused.
Yes, Sir, I am.
I'm not aware of anybody (but ME! more in a second) having an issue with the Rear. My problem was that the OEM bolts securing the center bushings to the Axle were rusted tight. Took me hours to get it apart. When you do the front of the Hellwig rear bar (where it bolts to the frame rails) you are replacing OEM link and fasteners with parts from Hellwig and you can follow their instructions for 1/2x13 USS Bolts.
The only issue I've heard about on Front is with the larger bolts on the fronts of the brackets holding center bushings to crossmember. A couple OP's have found them very hard to remove. And one OP stripped that hole, but he'd tried to enlarge it to late model (2008+) spec on an early (pre-2008) E450 that he'd installed a late model axle on. Ordered the late model bar and wanted bolt sizes to match. I think he had to have somebody come and do some welding to make it work.
Ford must have at least thought that the 2008+ required a bigger front bolt on those brackets. Why, when the axles are very close to alike, and the bars are the same size, beats me. But I'm not an Engineer.
