gfs1943
Sep 22, 2013Explorer
Help Needed: Basement Air Problem
Basement air conditioner quit working on our 2000 Itasca Horizon. AC blower works. Compressors run, but condensor blower doesn't run. It will sometimes start and run a few seconds, then shuts off. Compressors continue to run until (probably) the high-pressure switch shuts them off because there is no cooling air. Sometimes when I turn on the AC, nothing runs except the inside blower. Sometimes, it works as described above.
The condensor blower spins freely, so it's not bound up. I suspect a circuit board problem, or a sensor switch problem, but can't say for sure. Any help appreciated.
