goufgators
Oct 20, 2015Explorer
Ivylog wrote:
I use 76 and 294/68 fairly often in my MH. 76 is a little curvy and you do cross the AT but not a steep pull. 294 has been worked on recently and they straightened some of the curves. 68 is curvy too with one good climb and some of it is a little narrow but doable. If the inside of the curve has been widened it's a fairly sharp one so slow down. The leaves should be near peak so it will be a pretty ride.
At Tellico Plains I'd be tempted to unhook the toad and take 165/Cherohala Skyway scenic byway out and back as it should be spectacular. Would not even hook the toad back up for the 50 miles to Spring City.
Thanks! Just the info I needed.../ Larry
38,705 PostsLatest Activity: Jan 21, 2025
