homerbw wrote:
Our M/H is a 2000 Fleetwood Pace Arrow Vision 36B. As we were traveling, the electricity would go off.
1. I am assuming that the electricity issue is the house AC power while driving, not the chassis system or the 12v house system.
2. If the AC power from your generator goes off while traveling, it would seem that there is a loose wire or contact point.
3. If that issue is in your transfer switch and is affecting the 110v system, the problem might be resolved by cleaning and tightening the generator specific wire contacts inside the transfer switch. (Do this with no shore power and no genset power.)
That should get you home where more in depth work could be done, if even necessary.
If power from the genset into the coach is not being interrupted, then you do not need the transfer switch repaired/replaced.
I cannot tell from your description if the above is even your problem.
