Hot Water Not Working
ttharrisons
Hello,
My brother has a 2019 Entegra Vision 26X, and the hot water is not working, intermittent at best. He purchased it from our sister, and he's a first time ever. Any tips or areas to focus on?
thanks,
Derrick/Brenda/2 kids & Sissy (our Yellow Lab)
'01 Ford F250 SuperDuty Crew Cab
Triton V10 / 3.73 / Prodigy Brake Controller
'03 Jayco Eagle 305 BHS-5er
8 REPLIES 8
wa8yxm
Takes 30 minutes to make cold into hot on electric. It was working all along,.
ttharrisons
Water was coming out cold, but 30 minutes later, his wife called over to our camp site and said it was now hot. I don't know what made it start working....I know in my trailer, I flip the switch, run the water for about 5 minutes, and it becomes hot. Anyway, it's all working now! That's a pretty nice little motorhome.
thanks,
way2roll
Navigator II
Navigator II
I am guessing winterization/bypass valve.
Jeff - 2023 FR Sunseeker 2400B MBS
wa8yxm
Not working.
When you turn ELECTRIC the water does not get hot? { }
When you turn on the GAS no hot water and fault light { }
Suuburan { } or Atoood { } Model number ________
Water in the tank seem to be hot nut no or little hot at the sink { }
Please supply details
(Note the last one is not a water heater problem.. Is a Face Palm problem.. Outside shower (or in some cases inside shower but usually the otside) Mixer valves open. flow cut off at shower head.
enblethen
Need more information. Some rigs have continuous water heaters. Most have either Suburban or Atwood tank type.
Looks like it has a 6-gal tank type.
entegra specs
Find out whether they are running it on 120 volts or propane.
Ask if any lights come on the switch, they are operating the water heater.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
midnightsadie
#1 don,t light it intill your sure its full of water. if you did you burnt the electric element up.
midnightsadie
check the by pass valve
MitchF150
So what is "not working" when trying to use the hot water?
Is water not coming out of the faucet? Is there water, but it's not hot?
How is it set to heat the water? (gas/electric)
Depending on how it's set to heat, is anything else that uses that source working?
Good luck! Mitch
2013 F150 XLT 4x4 SuperCab Max Tow Egoboost 3.73 gears #7700 GVWR #1920 payload. 2019 Rockwood Mini Lite 2511S.
