paulgreenwood1's avatar
May 18, 2016
House Battery Dies Quickly
I own a 2004 Coachmen Mirada class A. Last year I replaced the house battery. Now my battery won't run my lights for more than a couple of hours before dying. As I live in Florida, I figured maybe the heat was killing the battery, but, after further reading, I'm not so sure. Can anyone suggest why my battery dies so quickly? Is there a way that I can check if it is being charged sufficiently when rv engine is on? I do alot of boondocking, so my HB is usually only being charged when I drive. I have noticed, however, that when I camp and am plugged in, the battery also does not last long after disconnecting from shore power.When the rv is not in use, I make sure to push the battery disconnect, so it is not in use when sitting for long times idle.Maybe just a bad battery? It is deep cycle marine battery. I also read that completely discharging the hb will cut down the life. In future, should I turn lights off when battery reads 1/3?
