- JoeHExplorer III
EMaznio wrote:
One really important fact I failed to remember and mention is that I have 2 Solec 90 watt solar panels on my roof that each produce 5 amps of charge per hour, per panel, in full sunlight (fortunately, I'm in Miami). The Monaco manual says that theirMonaco Owner's Manual wrote:
With this added info, do you think I'm in good shape to leave it for 2 weeks without our food being destroyed, so long as the LPG is full and the solar panels are clean?
extensive testing has shown that one 90 watt panel delivers enough power to offset normal day to day drain on batteries, caused by various parasitic electrical loads...This means that the first 90 watt solar panel is only intended to cover these parasitic loads. Adding a second can replace what is drawn out of the batteries from the operation of lights, water pumps, inverters, etc., while dry camping.
Yep ! - mlts22Explorer IIOnce that battery goes below 9-10 volts, the fridge's control board will display a "check" light (if a Dometic) and stop any boiler processes. Older refrigerators were propane only, so could just run for months on a twin set of tanks. Newer ones are limited by the battery... and at most, you have about a few days to a week before it stops. If one had a beefier bank (~500-1000 ampere-hours), two weeks might be doable.
Of course, a solar charging system makes this a completely different ball-game. A good amount of panels, a MPPT charger, and two six volt golf cart batteries would be able to keep the fridge running almost indefinitely. It likely won't be good enough to handle a furnace's amp draw after a few days, but for the fridge and the propane/CO/fire alarms, it should be fine. - EMaznioExplorerThanks for the reassurance everyone. I'm confident at this point to leave it without worry. Thanks again. All my best.
- garry1pExplorerIMO;
You should be just fine propane will not be an issue and the chance of the burner not working is remote, the batteries will stay up with the solar charge.
The frig uses very little propane and very little battery current. - Passin_ThruExplorerJust have your battery checked. Should be OK. Ours sits in the yard for weeks at a time and we always have the heat and the refr on. don't keep the dord attached except when it's cold and need the heat.
- LobstahExplorerAnd here comes the lawyers.
<-- getting popcorn ready :)
Jim - MrWizardModeratorWhere are you leaving it, your own private property or paid public storage
Guess what you could be in violation of their rules and local laws
By leaving the propane on and fridge running - crassterExplorer IIShould be just fine for that length of time. I'd think several months.
- chloe_s_ranchExplorer IIYes!
- EMaznioExplorerOne really important fact I failed to remember and mention is that I have 2 Solec 90 watt solar panels on my roof that each produce 5 amps of charge per hour, per panel, in full sunlight (fortunately, I'm in Miami). The Monaco manual says that their
About Motorhome Group
38,766 PostsLatest Activity: Jan 10, 2026
