Feb-05-2021 10:55 AM
Feb-05-2021 01:55 PM
dodge guy wrote:
When plugged in the chassis battery does not get charged, only the house batteries. The converter/charger on an 03 is as basic as they come so it can very well over charge the house batteries after extended time plugged in if you don't routinely place a load on the batteries.
Feb-05-2021 01:54 PM
Feb-05-2021 01:23 PM
Feb-05-2021 12:38 PM
Old-Biscuit wrote:
Unplug prior to moving MH
Feb-05-2021 12:18 PM
Feb-05-2021 12:00 PM
Feb-05-2021 11:50 AM
Feb-05-2021 11:46 AM
Feb-05-2021 11:28 AM
Sir Traveller wrote:If in storage, why do you need the Fridge or microwave to work??
Hello Everyone…
I have a 2003 Ford F-53 RV
I have questions regarding charging house & chassis batteries, How often to disconnect from shore power
I usually stay hooked up to shore power for 6 months, then leave the RV in storage for the other 6 months … So after 3 years of this schedule the chassis battery died even though I was hooked up for months , and now the deep cycle batteries are leaking .. (I did replace the starting battery )
What are my options in this case to increase the longevity of both the starting and house batteries? (Since the charging system is built in) disconnect from the shore power for few minutes every day? For few hours every week? Should I remove the negative terminal from the starting battery even when hooked to shore power? If so then how often?
Take into consideration that my fridge and microwave work only when connected to shore powerI do not know much about how electric systems work so that is why I ask all these details to make sure I get it right
Feb-05-2021 11:17 AM
Feb-05-2021 11:10 AM
