sloman2001's avatar
sloman2001
How to inflate to 110 psi....
OK, I know it sounds stupid, but I am unable to add air to my tires using the aux air connection from the MH. I need 110psi, but I think the cut-in/cut-out psi will not allow me to add air as the pressure is not high enough in the MH. Maybe I need to give it more time, but how long does it take any of you to add 6 lbs of pressure (to go from 104 psi to 110 psi),
How do you guys add air to your tires that need 110 psi? I have even tried a separate compressor that is suppose to go to 125 psi, but I can't get any air into them using that. Do I need to buy a separate larger compressor? As a newbie, this is one challenge I did not expect.
Thanks, Tom
