Sep-16-2021 01:05 PM
Sep-20-2021 07:19 PM
Sep-18-2021 07:41 PM
enblethen wrote:
It just acts like there is no control power to the pump.
Sep-18-2021 07:29 PM
Bud
USAF Retired
Pace Arrow
Sep-18-2021 07:08 PM
enblethen wrote:
One of small terminals is ground. Other pin should be control 12 volts DC. Not sure which is pin A.
Did you check for resistance between the small pins on pump solenoid?
Did you find the main control unit? There is several fuses there including one for pump control.
Has there some recent battery work done?
Sep-18-2021 06:07 PM
Bud
USAF Retired
Pace Arrow
Sep-18-2021 04:58 PM
enblethen wrote:
The one in the center is the one for the leveling indicators.
Jumper between the large posts on pump motor solenoid. See if pump starts.
If it does check the small posts for continuity.
Sep-18-2021 12:50 PM
Bud
USAF Retired
Pace Arrow
Sep-18-2021 12:34 PM
MountainAir05 wrote:
Take a broom and move the level sensor under your Rv. Mine is located about center. On the last page of your manual. Mine got stuck with slush one time and cause all sort of issue. I put a deflector in front of it so maybe it would not happen again.
Sep-18-2021 09:47 AM
Sep-17-2021 10:29 PM
enblethen wrote:the coach is parked at our home spot, = level
Your manaul reference is operators manual. One I posted is troubleshooting.
Top center appears to be excessive slope is that correct?
Sep-17-2021 04:04 PM
Bud
USAF Retired
Pace Arrow
Sep-17-2021 01:47 PM
enblethen wrote:
Which yellow light comes on?
enblethen wrote:
this is correct manual. Manual
Sep-16-2021 07:33 PM
Bud
USAF Retired
Pace Arrow
Sep-16-2021 06:14 PM
enblethen wrote:
Check to insure large cable to pump has power to it.
Should have a solenoid on it.
