et2
Feb 07, 2016Explorer
Canadian Rainbirds wrote:et2 wrote:
Extend them. Put some transmission oil on a rag and apply to the exposed shaft. Try retracting again and see if it improves. Check for obstructions. Last would be maybe a new spring is needed.
Oil can attract and hold dust. Silicone spray is better. Extend as said above, spray, clean with a clean lint free cloth, spray once more and try to retract. If it is the spring, (our right rear has been weak for years) you can assist it up with a long lever.
That is what is in the hydraulic chamber to begin with - transmission fluid. Many manufactures say specifically not to use silicon spray as it can react with the seal. Just apply and wipe off.
38,707 PostsLatest Activity: Feb 18, 2025
