Fishinghat
Feb 08, 2016Explorer II
I have a 1993 coach with the HWH levelers and all have their original springs. I can't help but think a slow retracting leveler is due to something else, such as dirty fluid, closed valve or dirty jack. I spray mine with silicone fluid just before retracting. The fluid seems to keep the seals lubricated, although I would assume MD3 fluid (automatic transmission fluid) would do the same, if not better.
I changed the fluid several years ago as a preventive measure. it takes about a gallon if I remember correctly. I also lubricate the zert fittings and spray the moving/pivoting parts with silicone spray. Remember to check the manual release valves on top of the pump to make sure they are closed.
38,707 PostsLatest Activity: Feb 18, 2025
