stppearson26,
With 4 adults plus occasional grandchildren, I think you need to be looking at units no shorter than 36’, either Super-C, or to be honest, I’d look at Class A’s. Instead of new, I’d look for a recent vintage unit which has already taken a good part of the depreciation hit. Plus, most of the bugs have been worked out so you don’t have to become a slave to your dealer/manufacturer. You WILL have to do frequent maintenance. Probably more on the coach part of the motorhome than the chassis. So, if you’re handy around your sticks & bricks house, then that’s a good start.
As others have said, you need a lot of space for the “stuff” of 4 adults. When you say “grand babies”, are these “babies” in the sense of needing playpen/strollers etc.? If so, you’ll need space to store these items.
Someone also mentioned weight issues. With 4 adults and packing for full-time use, you will need at least 3,000 lbs. of available cargo carrying capacity for people, food, water, clothes & stuff. You’ll want a unit with at least one main slide in the living area. You might also want to investigate 1 1/2 bath units, as well.
Larger rigs will have larger fresh water and holding tanks. For a larger crew, that’s definitely important.
Your mom may not be comfortable travelling in a motorhome. Depending upon the floor plan, some only have 2 forward facing seats: driver & passenger. Since you’ll be driving, she might have to be your co-pilot, but that might be optimal for you while driving. You also want to make sure your rig has a seat belt in each seated position. Some units, even 36’ long or longer units, only have 4 or 5 seatbelts. Our rig has 12, but that’s a bit unusual (3 on each sofa, 4 on dinette, driver & passenger). I did install seatbelts across our bed and when we traveled at night when the kids were young, we had them tucked into the bed with the seatbelts to keep them from rolling off onto the floor should the ride get a bit rough or if I had to hit the brakes hard. It worked. Not sure how they slept though. I tried it once while wifey was driving. It was loud and bumpy. Not sure if that was what kept me awake or just the fact that wifey was driving. It was probably the latter. :)
I will say that you’ve come to the right place for information. You’ll get opinions from a lot of people. I think your plan may be realistic, but not with such a small motorhome. Our 36’ in our signature was our first RV of any type. Driving it IS a learning experience, but usually it’s width & height that is more of a concern than length. Generally, when navigating side streets, you don’t want to start turning the wheel until the rear wheels have passed the point where you want the rig to turn. Turn like you would your car, and you’ll be in trouble. For most, though, you learn that pretty quickly.
Anyway, I hope you’re not too discouraged by some of the comments here. I think you need to set your sights a bit “bigger” and your plan could be doable and ENJOYABLE. But take your time and ask LOTS of questions here on the forums. In general, DO NOT BELIEVE what most RV salespeople say. The majority of them have never spent a day in their life camping, let alone camping in a motorhome.
Good Luck in your search,
~Rick
