str8shooter_mn
Oct 09, 2019Explorer
inside lights dim
I just replaced the coach batteries, 2-6v deep cycle. We are plugged into shore power. After a while our inside lights get very dim. Disconnected converter and checked out put. It is at 13.62 VDC as manual says it should be. Lights get bright again after starting coach. Running off of alternator Voltage.
What am I missing? Is there a relay somewhere that is supposed to switch from alternator to converter power to charge batteries when coach is turned off? Old batteries were shot, wouldn't take a charge.
