stevendeckert's avatar
Oct 07, 2021
Intellitec Bd2 replacement
I have a new to us 1999 Gulfstream Sun Voyager and it has the Intellitec BD2 battery control panel and it has gone bad and I need to figure out a way to replace it, apparently all of the upgrades are not available so my question is, can I do something different and still by able to have the batteries get charged while the coach is plugged into shore power.
  • You can do the upgrade which has the adapter harness. OR, just go to the Intellitec Solenoid and jump the wiring between the 2 LARGE battery posts. That will bypass the disconnect solenoid. Use a heavy 6 gauge jumper wire with ring terminals. Have you tried E Bay for that panel? Doug
    If you have the BD2 that means you have 2 solenoids. Chassis and Coach. If BOTH will not close and allow power, bypass both.
