I am thinking you mean converter. Your inverter inverts 12 volt power to 120 for use when you are not plugged in. Your converter takes the power from the plugged in wire, and inside the converter is a battery charger. If it is humming or buzzing, perhaps it is charging your new batteries.
Your converter also powers up all the 12 volt appliances, and it can hum while it is doing that too.
Mike
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers,
Triple E Motorhome and Fifth Wheel
