Mr.Mark wrote:
Daveb1256, the guy on the other site might be having this done for the second time and Cummins, at this point, is not standing up to pay for the repair.
This guy will have over $50,000 in engine repairs on his Country Coach if he goes for the second repair (hasn't broken yet, oil analysis is indicating heavy metals).
If the chances are 1 in 10,000 and if it's you, it will feel like every one of the engines are failing.
Personally, I wouldn't buy it unless you know that the serial numbers of failures are not in that band. If the number falls within the range, I would want to get the price down to cover the repair,
Good luck,
MM.
I believe that engine will be on its third time.
I think it was done before he purchased it. Then he had it done after it dropped the valve after his purchase and if I remember reading that thread a long time back Cummins can't verify what parts were used in the rebuild the second time so he might be doing it again.
