ronaz01's avatar
ronaz01
It hasn't run in a while.Starting issue
It's been a while since I last posted and I haven't had a chance to research and ask for advice/support. A little History:
*We have a 2001 Shasta with E450 V-10.
*Fuel pump replaced in 2008
*It was parked in June 2009 when gas was $4.00/gal.
*It had about 1/4 tank when parked and I would go start it twice/month and kept saying "I need to get gas" and never did.
*starting twice/month degraded to once then none. Work, Family obligations and laziness happened.
*I attempted to start it some months afterward and after several attempts it did start and ran reasonably and would die. former neighbor told me fuel pump was bad.
*I did research and discovered everything I didn't do; No gas, No fuel treatment (after cleaning several motorcycles and ATV's I know better now. Ethanol Sucks)
*Today went and got 12 gal of fresh gas and treated with Marine Stabil and Seafoam. Turned on ignition and heard relay click and the wife said she could hear the pump whine "Sounds like my motorcycle when I turn on the ignition" She said. I said "good". I primed the line by turning the ignition on and off about 5 times and it took a while but it finally fired a couple times. Several more attempts and it started. I gave it gas and died. Couple more attempts and it started and I just let it run to operating temp. I would give it gas and it would rev. Wife said it sounded good and the exhaust didn't smell after it it had run a while.
I shut it down and did a few other things and attempted to start again and it took it a few, not as many as before, but it did start and run nice with no bad exhaust.
My question is. Is the fuel pump bad and not pressurizing enough or is it just still bad gas? Fuel filter Bad? Also the Gas cap won't seal now. Probably because of age so would that affect it?
This is all my fault. I guess I should have sprung for the gas back in the day but finances were tight during that time as you all know. I am retired and have time on my hands and if need be I will drop the tank and replace the pump if that is the problem. I spent $1200 to have a dealer replace the pump once. I can't afford that again. Is it easy enough to drop the tank? I have a bad leg and can't move as well but I will if I have to. And just in time for Arizona summer!! Thanks for reading my Looooong Post
  • Battery is new and it cranked well but I will charge it. I was thinking (hoping) fuel filter. I am going to attempt to start every day this week and let it warm to operating temp. I need a new gas cap so I will get that as well. When the pump failed in 08 it wouldn't even fire at all. I will also check injector rail pressure.
  • I would think a combination of nasty gas and low battery. It would not be a bad idea to check or replace the fuel filter soon, too, as it could be largely plugged with junk from the old gas or the gas tank dregs.
  • Low battery voltage from sitting to long would be my thought.
  • My bet is you have some really bad gas. A fuel pump isn't going to fail just sitting there unused.
