suprz wrote:
The front end just needs to be "tightened up" for sure.
It's an easy project to tighten up the handling. You've been around here awhile so I hope you've weighed it and adjusted tire pressure to the actual weights. I think you'd be good at 65 front and 80 rear, but still better to check. That, and getting a proper "truck" alignment with CASTER toward the High Positive end of the range, not the 3* mid-range value. And certainly NOT a cheapie job where they "Set Toe and Go." Toe is important, but you NEED CASTER.
Anyhow, Hellwig Front and Rear Sway Bars are highly effective and easy to install. Start with the REAR if you want to try one end first.
IF your 2006 chassis needs front end repair, like Ball Joints and Bushings, And/Or a major brake job, like Calipers and Rotors, get a parts kit from Quigley and upgrade to 2008+ that gives you all new axles, re-designed radius arms, and all new brakes that have MUCH larger Rotors and Calipers/Pads. These come off of new chassis that Quigley is converting to 4x4 with F350 parts. Axle does NOT come with the Sway Bar, so get a Hellwig for the 2008+ axle if you do the upgrade. 2007- Hellwig will fit the newer axle, just not the opposite.
