- GjacExplorer IIIOne possible con not mentioned is if you forget to put the locking pin in after you fold it can fall and drag on the road if no tow car is attached. This happened to me once when I went to get gas for the MH, thankfully a passing car told me that sparks were coming off the tow bar. I now use a bungee cord to keep the two legs from extending when no car is hooked up as well as the locking pin. Another minor problem is if left on for several years the lock going through the pin can rust and penetrating oil is need to open the lock.
- JoeHExplorer IIIMine was put on the current coach 7 years ago... hasn't come off since.
- Elk_travelerExplorerI have the Blue Ox and I always leave on. I place a cover on when I return home and detach the tow. Blue Ox has the rubber grommets and plastic spacers which enable movement of the tow bar these certainly would be affected by the heat and sun but once covered I think they're ok.
- Dutch_12078Explorer IIOther than occasionally removing the tow bar for cleaning/lubing, it stays in place year round since we travel year round. I do install a weather cover when we're parked for awhile.
- TS21ssoExplorerI have a Blue Ox tow. bar, keep it on MH, covered with accessory vinyl cover. Remove it from MH once a year for cleaning, inspecting, and new grease on bars. Always clean and lube receiver before reinstall.
- STBRetiredExplorerInstalled with a locking pin, sprayed with silicone lubricant according to manufacturer's instructions, and kept covered when not in use. Goes on when MH comes out of storage, comes off when MH goes to storage. No problems at all.
- RRTomExplorer
wa8yxm wrote:
The cons are:
Weather exposure if the RV is stored outside
Legs.. If it not bolted on and locked (As in with a key) it the can grow legs .
It would be in a protective covering, and it would be locked. The motor home is backed in between our house and a block wall so the motor home (let alone the tow bar) is not noticeable. - wa8yxmExplorer IIIThe cons are:
Legs.. If it not bolted on and locked (As in with a key) it the can grow legs . - magicbusExplorer II
gbopp wrote:
Exact same thing happened on my first class A. I now use a receiver bike rack on my class B and I lube it well because I leave it on for 10 weeks in the winter but then pull it off when home.
We traveled quite a bit with the bar attached and folded up. It caused no problems and was not in the way.
When I finally removed it, I needed some penetrating oil and a big hammer.
Dave - CA_TravelerExplorer IIIMy joints and bar are sprayed with silicon lube as recommended which is less dirt attracting. Attached for 16 years with a lock which keeps honest folks honest. In recent years I've been leaving the car cross bar attached as well.
About Motorhome Group
38,705 PostsLatest Activity: Jan 21, 2025
