dougrainer wrote:
Gundog wrote:
What I found with mine is if the front starts out higher than the back when the back jacks come down and level side to side and raise the rear the front jacks may not be touching the ground at all. I re calibrated it about 5 times and called Power Gear tech support the guy told me that was normal for my leveling system and if I wanted the front down to run them manually.
Now if the front is low it will have all 4 jacks down after leveling. It is no big deal now that I understand how it works but when I first got the coach and leveled it at the house it did what I explained above and I thought something was broken. The tech told me the newer models test each jack after the leveling procedure to make sure they are all in contact with the ground but not the older ones.
HWH Auto/Computerized Leveling have ALWAYS checked that all 4 jacks have hit the ground, at least for 30 years. EACH HWH jack has a pressure switch that confirms and tells the system when each jack has hit the ground. Doug
We both have Powergear leveling. (We both have 05 Expeditions and have been comparing notes).
I agree if someone is moving around it either levels incorrectly or you get the “can’t level” blinking lights.
I have never noticed the front jacks not touching though. I will check someday.
