WNJeffers
Jun 15, 2016Explorer
Locked out - 1997 Safari Sahara
We had excess guests over the weekend and early this week, so I had my daughter and son-in-law sleep in the coach, which is parked out back with full hookups.
I just went out to get sheets and towels to wash and I find I cannot open the door. The deadbolt is not a problem, but the other lock will not open. We have never used this to lock the door, from inside or out, always the deadbolt only. As I’ve never used this lock, I have no idea which key should open it if locked. The key for the basement compartments will go in the lock, but will not work. The key for the service bay doors will not go in the lock. I’m not aware that I have another key; if I do, it is locked inside with the spare keys. I do have an extra deadbolt key available, but that is not the problem.
I assume that they used this problem lock to lock the door at night, and maybe got it unlocked only barely enough to open the door, but when the door shut again it fell into the locked position.
Can anyone tell me if the key for the basement compartments should open this door? Or the ubiquitous CH751 key use in the entry locks in travel trailers and fifth-wheels?
Should a locksmith be able to open this without totally destroying the lock? Can anyone tell me the brand of lock used, so I can research it myself?
Anyone faced a similar problem?
Any thoughts on how I may gain entry, either by defeating the lock to open the door, or otherwise gain entry while doing the minimum of damage to be repaired later?
Thanks!
Wayne
1997 Safari Sahara 3540
Thanks!
Wayne
