AikenRacer2's avatar
AikenRacer2
LP gas leak
2012 Thor Tuscany 42' motorhome. Long story short, the tank level gauge that is screwed into the side of the tank is leaking around the threads when I had the tank filled. I tried to tighten but did no good. Seems like I need to empty the tank to repair. Tank now used down to about half. The leak is barely enough now to bubble the soap solution. So my plan is to empty the tank fully, unscrew the gauge, retape the threads, etc. I want to pressure check with air before putting in gas. I would also like to replace the fill and vent hoses with the system empty. Hoses look good but they are 11 years old. I am open for ideas on this situation. Not real sure how to get the tank 100% empty.
