โOct-30-2017 11:58 AM
โNov-04-2017 07:46 PM
11178adm wrote:
a quick and dirty way to prime is to loosen the fuel line as close to the injection pump as possible and with a with a air blow gun put air pressure in the tank through the filler pipe using a old towel to seal the air, don't get too much pressure in the tank 3 to 5 psi will do. have an assistant tighten the line when you get clean fuel with no air bubbles, it should start after that. also check for fuel leaking any place between the tank and the fuel lift pump.
hope this helps
โNov-03-2017 08:10 PM
โNov-03-2017 07:30 PM
โNov-01-2017 08:42 PM
โNov-01-2017 07:24 PM
โNov-01-2017 07:15 PM
โOct-31-2017 07:01 PM
Tinstar wrote:gutfelt wrote:
with key on you should hear the prime pump; maybe the prime pump is not activating for the same reason the fuel shut off solenoid is not on my ISL its right on or near the engine as I can hear it running when keys turned on
As best I can tell, there is no electronic fuel pump and the only one is the mechanical pump at the lift pump. I got shut down by rain so when I can I'll take a fuel line loose at the pump and crank it over. Hopefully, I'll get fuel flow.
โOct-31-2017 05:53 PM
โOct-31-2017 10:26 AM
Tinstar wrote:
Does anyone know where the fuel pump might be and how to get to it? It's probably inside the tank but I don't know. I removed the filter and cranked the engine over. I am not getting fuel at the outlet when cranking. The filter is about 1/3 full so I definitely do not have prime. I suppose I should be getting fuel at the filter when cranking the engine.
โOct-31-2017 10:05 AM
โOct-30-2017 07:28 PM
wildmanbaker wrote:
JC, when you pump the primer lever, does it get hard and not pump anymore? If it doesn't, then locate the last filter before the injector pump and loosen the pressure tap fitting and bleed out the air.
Good luck.
โOct-30-2017 04:36 PM
โOct-30-2017 03:10 PM
โOct-30-2017 03:00 PM
