turbojimmy
Jul 02, 2014Explorer
Mysterious Electrical Issue
Looking for speculation/opinions on what might be going on here....
It all started when the HW heater blew its fuse. I determined the cause and fixed it. Not having any spare fuses, I pulled a fuse from a spot marked "SPARE" in the panel. I suspected it wasn't really a spare because there was a red wire attached to the lug that disappeared into the wall. But, removing the fuse didn't really seem to affect anything - at least at first.
So I'm replacing my toilet. Another long, boring story about a project that should take 15 minutes but is dragging on into days. But I digress. While working in the RV I noticed that the lights were flickering and eventually went out. Upon closer inspection, the lights that were "out" were very dimly lit - they were getting a tiny bit of power from somewhere. The other light circuit - powering the other half of the RV - was fine. I unplugged the shore power and plugged it back in and everything was fine again.
Well, it did it again this morning so I thought about what might be different. That fuse. I yanked the fuse from the WH spot and touched it to the "SPARE" spot. All the lights turned back on. But get this - I didn't install the fuse - just touched the contacts momentarily. WTH? Because it was obvious that this fuse is of great importance to the balance of my lighting universe, I reinstalled it. But the question is - what is it powering that has this effect on just one lighting circuit?
Ideas?
Ideas?
