keith1030's avatar
keith1030
new batteries motor and gen stopped turnong over
I replaced the rig whit new batteries and a new solenoid for the generator. Everything started up as expected. two days later clicking in the generator and motor wont turn over.
checked to make sure there wasn't a drain on the power, went back and cleaned all the wires and cleaned the ground cable at the body.
tried to start the generator from battery direct same problem , loud clicking.
is it possible the new batteries from pep boys are
bad or the solenoid at the battery went bad ?
  • If nothing was left on then have them load tested as you want to know - batteries or something else.
  • check to make sure that the battery polarity is right with the batteries. Sometimes someone will wire the four batteries wrong and you do not get the full 12 volts.
  • Yup pepboys is not know for great batteries... If clicking sounds like a low or dead battery to me... see if you can charge the battery from an external battery charger and see if it holds a charge...
    Mike C.
