daugen
Aug 18, 2013Explorer
New Onan generator died
Our 2013 Itasca Sunstar 27N comes with the 2500kw Onan gen running on gasoline. It was always hard starting, taking up to ten seconds of cranking. We were then told to hold down the stop button to prime it first. Ok..., No difference whatsoever in starting.
Then yesterday, after running for about an hour, the gen stopped.
Smell of gasoline from outside the compartment. It was late, so I waited until this morning to investigate and let it cool down.
Ok, what should I look for? 24 hours on gen. Will check all breakers first, then will see if there's a fuel filter in there. Then will try to restart. The oil is fine...
It's the smell of gasoline outside the motorhome that concerned me.
That I need to find the source or cause of for sure.
I'm not a mechanic, and the new rv is headed back to the dealer anyway, but I'd sure like to figure this out today, if that's possible.
After I check on it, I'll let you know what I find, which I expect to be nothing visible. There is a manual start on the gen right on it and that's where I'll see if she fires up.
