May-02-2017 08:47 AM
May-07-2017 11:55 AM
Justin210485 wrote:
Ok so is it possible to run the lights off of the batteries themselves which are charging when the truck is running completely bypassing the converter? That's the only way I cpuld figure that the converter is not connected but things still work.
May-07-2017 11:34 AM
May-06-2017 01:35 PM
May-06-2017 01:02 PM
May-05-2017 04:34 PM
May-03-2017 09:35 PM
May-03-2017 05:25 PM
May-03-2017 04:36 PM
May-03-2017 03:58 PM
May-03-2017 03:09 PM
May-03-2017 02:33 PM
DrewE wrote:
The inverter produces 120V power from the 12V power from the batteries for powering whatever sorts of 120V devices you want to power when not connected to shore power. (Obviously there are limitations on how much power is available from an inverter.) Common examples include 120V televisions and other entertainment devices, laptops, crock pots, and maybe limited microwaving if the inverter and battery bank are sufficiently large.
As to why the 120V power to the fridge was cut, your guess may be as good as mine. Possibly there was some fault in the fridge or in the outlet it plugs into (water got into the outlet maybe).
May-03-2017 01:57 PM
May-03-2017 01:00 PM
May-03-2017 12:48 PM
Justin210485 wrote:
Update: so I guess I just wasnt patient enough with the fuel tank switch. Today while driving I flipped it for the he'll of it , was also near empty. After about 5m the fuel gauge slowly rose to 1/3 tank. So that's great.
