melandme wrote:
I have done both the Hellwig sway bars and the Sumo springs on a 2016 25B. Put both front and rear sway bars on at 5K miles. Really made difference when being passed by big trucks. I describe it as going from a shove to gentle push. Installed Sumo springs this summer at 38K miles before a trip to Vermont. With the Sumos when a truck passes there is still a push but more like a nudge. Where I notice the Sumos most is there is less side to side rocking when turning in and out of parking lots and other places at slow speeds. The wife says the ride is better when sitting back in the coach. When at the camp site you do not get as much bounce when moving in the coach. As for smoother ride over rough road, after driving thru WV and MD interstate construction, they didn't seem to help much.
I have no first-hand experience with Sumo springs, but I wonder if our heavy duty Bilstein-RV shocks achieve similar results under the conditions you mention.
When it comes to softening the ride, lowering your tire psi to the actual weight being carried, is most effective.
During your weigh-ins, if you learn that your front suspension consistently has a lot of excess load margin, then you might want to consider what I did
HERE which helped soften the ride for us and the house up front quite nicely. Our 2007 E350 front suspension originally was rated for 4600 pounds, but our actual weigh-ins have been consistent at 3260 ponds. The 1340 pound difference sounds negligible, but for ride comfort, it is a lot. I replaced the 4600 pound springs with 3750 pound progressive springs which yielded great results. We can still add an extra ~400 pounds on the front suspension before reaching the reduced limit, so if we have some extra passengers, we are still in good shape. But it's been just the two of us for nearly every trip. We've had an extra person with us a few times for short durations, but each person weighed less than 140 pounds. I assume half of that weight of 70 pounds was placed on the front suspension at that time.
