nosnow wrote:
Looking for advice on used diesel motorhome. We are looking at 36 ft and our choices are all 2001 t0 2005, Itasca Horizon, Holiday Rambler Ambassador, Monaco diplomat, and Airstream xc360. How do these rank in build quality, all have one piece solid roofs either alum. or fiberglass. Major problems with any of them?
Thanks for any info,
Nosnow 🙂
Nosnow,
Well Sir, we have pretty much exactly what you're looking at or, thinking about. Ours is an '04 Itasca Horizon 36GD with the C-7 330HP CAT and Allison 3000MH trans. It's been an outstanding unit in the 3.5 years we've owned so far. Yep, I've had to do some repair here and there. And there's been general maintenance. Ours is the full body paint model. Having a unit like that, with that finish, I don't think I'd ever go back to a non-full body painted unit. They're so, SO much easier to maintain and polish.
The Itasca and Winnebago product are pretty much bullet proof. There is outstanding support from both Winnebago/Itasca and, Freightliner chassis too. The C-7 has performed outstandingly. The Allison trans has also lived up to its name and reputation, just great. We have the fiberglass roof which, in my opinion, is far superior to any rubber roof ever made. I know because we had one on our previous coach, a '99 Fleetwood Bounder 34V.
The interior construction, fit and finish is top notch. Our cabinets are solid wood, doors, drawer fronts and framing. The basement A/C combo Heat pump unit has also been great. The only thing I've had to do to that unit is, install a bearing in one of the fan supports. That's something that's been done by many owners. It's a simple task. Freightliner has been outstanding in support when ever I've called about a question or, a repair issue. They know every nut and bolt that went into my particular coach.
Our unit, a 36' coach, handles great. I've even mounted a Hydralift on the back and carried a Honda GL1800 Goldwing on it and it still, ran down the road true and straight with no ill handling effects, no wandering, no porpoising, nothing. The coach took care of itself in terms of ride height. That's since been changed and we tow a GMC 1500 Sierra Extended Cab 4x4 that carries the bike now.
I do all of my own maintenance and repairs. We hover around 7,000 to 10,000 miles a year in travels. It has never let us down with one exception. And even that, it still kept on running and driving normal. I'll explain later if you want to know, in a PM. I will say this, if you go the later model, as in '04 and above, you'll get a slide out tray for your generator which, by far, is an outstanding feature to have in terms of maintenance and repairs for that generator. I have friends that would kill for a slide out unit.
The later models also have better interior lighting and, in many cases, better dash componentry. And, the later ones, as in '04 and above, have better electronics in terms of computer controls, engine analysis and more. The '03 units and older utilize what's called a VDC or, Vehicle Data Computer for coordinating signals between engine operations and, your gauges. The newer coaches, as in '04 and above, utilize what's called the MMDC or, Multi Module Data Controller. It does the same thing only it's much more refined and can process information much faster. The VDC was trouble prone due to inferior solder joints in the circuit boards. Not all of them, but many.
We get many, many nice comments on our coach. Many folks think ours is way newer than it is, based on it's looks. Of course, ours has had the good fortune to be under a roof for its entire life. We recently moved to Lake Havasu City and it's now sitting in brand new home with an RV garage attached. It only sees the elements and the sun, when we're in it traveling.
Please feel free to PM me if you'd like any additional info pertaining to the Horizon model. Be very glad to help.
Scott
![](http://i479.photobucket.com/albums/rr159/FIRE-UP1/06HEXT52.jpg)
![](http://i479.photobucket.com/albums/rr159/FIRE-UP1/photo_zps6b651c4f.jpg)
Scott and Karla SDFD RETIRED2004 Itasca Horizon, 36GD Slate Blue 330 CAT
2008 Caliente Red LVL II GL 1800 Goldwing KI60ND
