Jul-09-2016 08:12 PM
Jul-19-2016 04:57 AM
crasster wrote:diplomatdon wrote:
Turned on the fridge for the 1st time this season, and it keeps popping the GFCI. All the electrical wiring and plugs seem good on the circuit, runs on LP but throws reset on AC. Could there be a problem with control board. Any help appreciated. Don
Could be a weak GFCI. I'd test it with several power tools, such as a drill, circular saw, and also perhaps a space heater. If GFCI trips, faulty plug.
Jul-19-2016 04:54 AM
Jul-19-2016 04:21 AM
diplomatdon wrote:
Just a update on problem. Tried all the things mentioned as far as other appliances etc. causing problem. Not the issue. Tried new GFCI and not the problem. Would work if GFCI bypassed as Doug said, however the other plugs on the circuit not protected. We went away for a week, ran on LP. When we got home I checked the OHMS as Norcold Guy showed on his site. Resistance was within tolerance, put back together, plugged in and working fine. Guess it's good until the next time it happens. Don't know what the problem was but I claimed to the wife I fixed it. Thanks for every ones help and suggestions. Don
Jul-18-2016 08:51 PM
Jul-15-2016 07:14 AM
Jul-15-2016 07:02 AM
Jul-10-2016 02:48 PM
Old-Biscuit wrote:
Norcold 1200 has 2 (TWO) elements......225W each
Need to replace both.
Can be done from lower vent opening
Unplug leads on control module......pull elements up out of sleeves.
May need to wiggle back/forth to loosen
Small access door held in place via a tab. Bend tab then squeeze housing to unlock tab from door slot. Lift door slightly up and then out.
Jul-10-2016 06:41 AM
Jul-09-2016 10:27 PM
Jul-09-2016 09:24 PM
Jul-09-2016 08:16 PM
