noleakman's avatar
noleakman
Norcold 1200
I have a 06 National Sea Breeze with an Norcold 1200 fridge! my question is if you have it set on 2 for temp and you are in cool weather and you are on gas when it gets to temp will the gas burner shut off an on with the temp inside the fridge gets to cold or to warm?
  • Regardless of ambient air temps......
    Fridge thermostat controls propane or electric element heating cycles based on food compartment FIN temp which is sensed by the thermistor attached to fin
  • Yup, it's automatic. If you start having cooling issues, first thing to check are the outside fans. The sensor for them is on the top of the coils on the back and is known to fail. Cheap, easy fix.
