Roger_in_VERMON's avatar
Jan 20, 2015
Norcold door gaskets
I'm looking for new door gaskets for the two main doors of our Norcold 1200. Would appreciate any help. Thanks
  • NO gasket replacement for 1200
    Can replace the door with new gaskets. Cost to replace all 4 doors $1600-1800
    Lower LH - pn 627978
    Lower RH - pn 627991
    Upper LH - pn 627601
    Upper RH - pn 627603
    Personally I would see about warming gaskets until almost hot then closing door and letting them reset.
    Or slipping some roll foam gasket behind gaskets
    Or using some flat foam material on door edge
    Or cutting gaskets off doors and getting some self adhesive gasket
  • Trackrig wrote:
    An internet search shows Norcold refer gaskets possibly on Amazon, Ebay and from Norcold. Also look here:
    Refer Gaskets
    Bill
    Neat --- make a link that goes to windshield repair, has nothing to do with the topic.
  • If you find the normal part number, cross reference it on Ebay. They can often be found a lot cheaper.
  • Another ridiculous aspect of the Norcold 1200's. Need a seal, buy a door! Tear or damage a door seal and you're scr^&%$.
  • IIRC...Norcold says the gaskets aren't replaceable. They will, however, sell you two new doors.....:M...Dennis
