Seekeroflight's avatar
Jul 13, 2014
Norcold Recalls
Just a reminder that the Norcold Recalls are much more extensive than only the 1200's. Mine is one of 25,000 - 482's and is also on the list. I suggest that if you have any Norcold you might be wise to pursue this recall.
P.S. this applies to all RV's with Norcolds.
  • This is the recall that pertains to the 8 series
    http://www.norcoldrecall.com/
  • My fridge was on the recall list, so I called norcold. They sent the new parts and even called my repair guy to set up an appointment and said to call back to make sure I was Happy.
  • what part is on this recall they replaced that box that clips to the coils and is the part hard to replace
  • It's been my impression, after watching web chats such as this one, that there are more problems with the Norcolds after the recalls than before.
    And all this to fix a problem, the frequency of which is unknown.
    Amen.
  • The only real fix for a Not-So-Cold is the Samsung 197 RR.
    JR
    JR
    Or replacing the rear coils with Amish built ones. David Force is the person to contact at the phone # listed on the site. Very knowledgeable, very helpful and will return your calls if leaving a message.
    http://rvcoolingunit.com/Default.aspx
