doublev
Jul 26, 2016Explorer
Normal for onan 12.5kw to die when coming off shore power?
With the heat, I like to fire up the generator while plugged into shore power. I dont know if this is a problem or not but when the coach flips over to the generator (which it will do after 20 or 30 seconds of starting it up), the generator will die immediately if I have a full load on it (3 AC units and all that fun stuff).
My fix is to turn the AC off for about a minute to let the generator warm up and then I will turn on 3 AC on and it is fine (in the interim all of the other house items are putting some load on the generator).
Is this normal? I tend to think a generator probably does not like going from 0 amps to 50-60 amps instantly (about 25-30a per leg) 30 seconds after it has been turned on. But I want to double check and if it is not normal, what does this tend to indicate as a problem?
Generator otherwise works great. We can run it all day without any issues at all.
