et2
Apr 18, 2019Explorer
Ohio toll road E Z pass
I just ordered a Ohio E Z Pass online for a trip using OH & PA turnpikes. Couple questions. Where is the best location so it reads when passing the toll lane. At bottom center of dash? It says on-line behind rear view mirror ( that won't work). So that being positioned up higher on the windshield has me concerned - if I set it up on MH dash, centered.
The next is the class designations to pick from were real confusing. We have a MH with a tag. So three axles there, and the toad two axles. Total of 5 axles and 12 tires. Over 7000lbs. So that's what I put down. Not sure if I picked correctly as there was a lot of options.
I'm assuming that won't matter as the reader will calculate correctly?
Thanks!!
Thanks!!
