buckeyejoey wrote:
Do you find the smaller head gives more water pressure over a larger shower head. I replaced my shower head when we first bought our used 2006 Georgetown 340 as the original was leaking when we flushed the RV antifreeze.
I was wonder if I need to go to a smaller shower head to get more pressure at the head (could this be a water restriction problem with a fixed regulator at the water hook up?)
Try the Oxygenics Shower head that everyone is referring to here. You'll have all the pressure you need from an RV shower head. Even in situations with low pressure, it amplifies the low pressure to make it more acceptable to use.
Oxygenetics Body Spa Shower HeadI was skeptical at first, but decided to try it. Best money I'd ever spent on a shower head. In fact, I'm probably going to buy a spare to have on hand as a back up, should anything happen to the one we currently use.
