jyrostng
Jul 03, 2013Explorer
sc3283 wrote:
heat wrap on the steel jackets and on wire if need be and a different brand of plug wire....you say you bought the best....that may be the case in the Borg Warner line....but plug wires will last more than 800 miles
you dont have leaking/warped exhaust gaskets directing exhaust right onto the failed wires do you?
Use the heat wrap on the header tubes...Jegs and Summit and various other retailers sell the heat wrap
no leaks, victor blue gaskets cured those problems, the first plug wires I bought lasted less than 300 miles, the ends turned to goo. I bought the most expensive wires the place had with the borg warners, around 70 dollars. the wires seem ok, inside the steel jacket is ok, the chared part is the exposed part between the jacket and the wire.
the wires with the correct ends that fit the steel jacket covers limits the choices in wires. I'll try the wrap, thanks.
38,707 PostsLatest Activity: Feb 17, 2025
