dtucker3usa wrote:
That's exactly what I'm having them do. They tried to tell me that changing the brake fluid would cause other problems. I figured it couldn't be any worse than having no service brakes after driving for a hour and a half. Wish me luck.
I originally thought that you had a parking brake pedal going to the floor, along with the AP system and maybe you do. A manual parking brake pedal that is.
With 4 wheel service brakes pedal going to the floor, it could be just air in the lines or with boiling brake fluid. Usually the latter will recover in 8 hours or so, but should be replaced, as the boiling point is more around 212F, rather than 400F+.
The solenoid could be part of the AP system and do know that the V3 self contained system has one. Prices you quote seem out of sight and I would have run by now.
Again, keep in mind that the AP system has nothing to do with or is there any connection to the service wheel brakes. Manual, AP or both is a drum brake on the drive shaft and behind the transmission. As for emergency brakes, there is none on any vehicle I know of. They are parking brakes and maybe might stop you if not going more than a few mph.
I've never seen an old P30 gas coach more than 34ft that didn't have a tag axle, but it is what it is. At 34ft, they usually have a GVW of not more than 15K lbs, have a tranny parking pawl and don't require the AP system.
