richard1112's avatar
richard1112
polymer coating
I had a polymer coating applied to my roof, after the installer did it by 3 months the coating started to bubble
The coating was SaFe T Flex 520 from Brentwood Polymer Coatings Company, in Barrie ont and in Atlanta Georga. any one else have this happen. thanks
Richard
  • I ended up using a product called RexoSeal bought it at an RV dealer in Peterboro ont .5 gal pail 524.00 The installer that sold me the Brentwood coartongs **** came back and installed the new one for me at no charge, Its been on all summer and no problems. Ii am going to check out this Superior Polymer in Angus Ont apparently this is the same guy that owned Brentwood Coatings .
    when he went bankrupt
  • richard1112 wrote:
    usersmanual wrote:
    6mike60 wrote:
    I also used the Brentwood Coatings Safe T Plex product, on my 5th wheel trailer. I installed it in March, 2015. I had my first bubbling problem in March of 2016. They sent me instructions and replacement material for the areas affected.
    Then in November of 2016, several different areas on my roof started to bubble/blister. I emailed the company and sent photos. I have not received any response this time! Further investigations show the website is gone and phone numbers disconnected! Looks like they have gone out of business and left us with a failed product.:(
    I'm currently searching the web for a replacement product, looking at www.epdmcoatings.com.
    Anyone else?
    Mike
    I see flex seal now advertising a pretty good roof or whatever seal by the gallon? about 89.00 per gallon
  • Be sure the FlexSeal stuff has UV protection. Some of the spray stuff apparently does not.
    With that said, I did use it on a stick built house as a temporary repair and it worked as advertised until a permanent repair was done.
    I had the same result, the apllicater person, told me the same last may 2016 says its a mfg warranty not his, thanks for the info , I will check out flex seal and epdmcoatings
    I am a installer of the safe-t-plex and the owner of Brentwood Coatings is the same owner of Superior Polymers out of Canada,
    Brentwood Coatings went out of business....
  • I had the same result, the apllicater person, told me the same last may 2016 says its a mfg warranty not his, thanks for the info , I will check out flex seal and epdmcoatings
    Anyone else?
    Mike
    Anyone else?
    Mike
    Thanks for the info Mike!
    Anyone else?
    Mike
  • I also used the Brentwood Coatings Safe T Plex product, on my 5th wheel trailer. I installed it in March, 2015. I had my first bubbling problem in March of 2016. They sent me instructions and replacement material for the areas affected.
    Anyone else?
    Mike
    Richard
    Based on this I would be calling them and find out what went wrong???
    With over 9000 packages sold and no reported failures, we are confident that the Safe-T-Plex RV Roof Coating System is one of the best in the industry. Because we use only superior ingredients in our formulations, our product is not the cheapest on the market, however, if a durable, lasting, maintenance-free roof surface is what you are seeking, consider investing a little extra to get the ultimate in roof protection.
