Colo_Native's avatar
Colo_Native
Power gear Jacks
Jacks won't go down error according to the manual is RF lites blinks checked the connections still don't work even gave a little whack with a hammer on the pad still nothing and yes brake on in park etc any ideas thanks.
  • I am going to suspect these are electric. You may want to fill out your sig so we known what rig you have. Go to this link CLICKYat Power Gear, download the document on testing the brake. I suspect a corroded electric brake. If it is the brake, and you can't clean it, you can order one from Fleetwood for about $60.
  • wa8yxm's avatar
    wa8yxm
    Electric or hydraulic.. Suspect Electric, and if so I can not assist.
  • I have ran through the manual override step and it will not go down. Is it possible it is a bad jack?
  • could be your brakes on the jacks that are blinking are stuck, if so you will have to un-plug brake at jack and either run then down with drill or a 12 volt supply. powergear has it step by step on their web site!
  • I suggest you go to their website, they have a troubleshooting page.
    http://www.powergearus.com/products/leveling-systems
